How to Export Stiffness and Mass Matrices in COMSOL Eigenfrequency Study
I'm using COMSOL Multiphysics to perform an eigenfrequency analysis of a cryogenic suspension beam for a gravitational-wave detector project. I want to export the stiffness matrix (K) and mass matrix (M) for each mode, so I can compute the energy using the quadratic form:
externally.
Issue: I followed these steps:
  • Created an Eigenfrequency study (with or without prestress).
  • Added a Matrix Export node under "Derived Values."
  • Selected “Stiffness Matrix” and “Mass Matrix” with options "Global" and "Sparse."
However, when I try to export, COMSOL gives the error:
"K is not stored."
I’ve also tried switching to frequency-domain or stationary studies and adding Input Matrix nodes under the solver configuration, but nothing has worked so far.
My Questions:
  1. Is there a correct way to configure the eigenfrequency study so that the stiffness and mass matrices are stored and exportable?
  2. Does this feature require enabling something before solving?
  3. Is there any workaround if I don’t have LiveLink for MATLAB or Java API access?
Any guidance would be very appreciated
2 Replies Last Post 22 avr. 2025, 13:05 UTC+2
Posted: 22 hours ago 22 avr. 2025, 12:32 UTC+2
Updated: 22 hours ago 22 avr. 2025, 12:37 UTC+2
In study right-click on solution(sol 1) and use Other->Assemble and choose the data you want to store. After solving: in Results right-click' Derived Values' and use System Matrix.
https://www.comsol.com/blogs/implementing-the-weak-form-with-a-comsol-app#equation1
Nice Greetings
> Is there a correct way to configure the eigenfrequency study so that the stiffness and mass matrices are stored and exportable? In study right-click on solution(sol 1) and use Other->Assemble and choose the data you want to store. After solving: in Results right-click' Derived Values' and use System Matrix. [https://www.comsol.com/blogs/implementing-the-weak-form-with-a-comsol-app#equation1](https://www.comsol.com/blogs/implementing-the-weak-form-with-a-comsol-app#equation1) Nice Greetings
Posted: 21 hours ago 22 avr. 2025, 13:05 UTC+2
However, for this purpose there is no need to do this operation at all, since the energy is available as a built-in variable.
Henrik Sönnerlind
COMSOL
Reply
