Batch syntax for parameter values
I am running COMSOL in batch mode and having trouble entering parameters using the command line arguments -pname and -plist. Below is an example of how I entered the command with the parameters "p_start", "dp", and "p_end" defined in the file "input.mph". The file runs but the parameter values entered on the command line are ignored.
comsol batch -inputfile input.mph -outputfile results.mph -pname p_start,dp,p_end -plist .25,.5,3
I am guessing that I'm missing something in how to structure the command, but I could not find an example in the documentation. Could someone point out what I'm doing wrong?
John
6 Replies Last Post 16 déc. 2016, 09:01 UTC−5
Posted: 1 decade ago 21 sept. 2010, 11:03 UTC−4
I have never tried that one, but perhps a "Comma-Separated list of parmeter ..." means that there is a "" required around them or a [] or {}, it's true I connot find any examples, only with one variable and one value. That could be made more explicit.
In the programmers guide pname is to be a "string", but this does not really help much
Hi I have never tried that one, but perhps a "Comma-Separated list of parmeter ..." means that there is a "" required around them or a [] or {}, it's true I connot find any examples, only with one variable and one value. That could be made more explicit. In the programmers guide pname is to be a "string", but this does not really help much -- Good luck Ivar
Posted: 1 decade ago 21 sept. 2010, 11:12 UTC−4
Using quotes didn't work either (i.e. -pname "p_start,dp,p_end" -plist ".25,.5,3") . Thanks though.
Posted: 1 decade ago 17 févr. 2011, 07:37 UTC−5
I don't know if you are still interested by the answer, but I got the comsol batch + pname / plist command to work, also with many parameters. In a nutshell, the key seems to explicitly add a 'Batch node' in the relevant study for this to work.
At first I tried what you probably did also: I just created a model, with two parameters (defined under Global Definitions -> parameters ) and some studies.
I tried running:
comsol batch -inputfile input.mph -outputfile output.mph -study std2 -pname param1,param2 -plist 0.1,0.3
to run my job with param1=0.1, and param2=0.3. It did not work, in the sense that the calculation was done using the values for the parameters given under Global definitions.
Then, I added a batch 'node' to my study2, and clicked show default solver in the 'job configuration' panel. I saved my file, and ran comsol batch in the exact same way. This time however, the value of the parameters were read from the command line, as expected.
Another important thing I observed is that you cannot have blank spaces between your parameters or in the parameter list. For example:
-pname param1,param2 -plist 0.1,0.3 will function
-pname param1, param2 -plist 0.1,0.3 will not.
I hope this helps
Charles
Hi, I don't know if you are still interested by the answer, but I got the comsol batch + pname / plist command to work, also with many parameters. In a nutshell, the key seems to explicitly add a 'Batch node' in the relevant study for this to work. At first I tried what you probably did also: I just created a model, with two parameters (defined under Global Definitions -> parameters ) and some studies. I tried running: comsol batch -inputfile input.mph -outputfile output.mph -study std2 -pname param1,param2 -plist 0.1,0.3 to run my job with param1=0.1, and param2=0.3. It did not work, in the sense that the calculation was done using the values for the parameters given under Global definitions. Then, I added a batch 'node' to my study2, and clicked show default solver in the 'job configuration' panel. I saved my file, and ran comsol batch in the exact same way. This time however, the value of the parameters were read from the command line, as expected. Another important thing I observed is that you cannot have blank spaces between your parameters or in the parameter list. For example: -pname param1,param2 -plist 0.1,0.3 will function -pname param1, param2 -plist 0.1,0.3 will not. I hope this helps Charles
Posted: 1 decade ago 29 sept. 2014, 16:52 UTC−4
I found your reply really helpful for me.
I am in trouble with the output for comsol batch. I am using comsol without GUI in a Linux system.
I want to export the temperature of the node with tag pev1 in a .txt file. What command should I type?
I am looking forward to your reply.
Hi, I found your reply really helpful for me. I am in trouble with the output for comsol batch. I am using comsol without GUI in a Linux system. I want to export the temperature of the node with tag pev1 in a .txt file. What command should I type? I am looking forward to your reply.
Posted: 8 years ago 15 déc. 2016, 03:39 UTC−5
Another subtlety for the case of a negative parameter:
-pname t_input,Duration,CYC -plist 303.15,900,-1 will function
-pname CYC,t_input,Duration -plist -1,303.15,900 will not
Seems that minus sign is misinterpreted when it follows -plist
Another subtlety for the case of a negative parameter: -pname t_input,Duration,CYC -plist 303.15,900,-1 will function -pname CYC,t_input,Duration -plist -1,303.15,900 will not Seems that minus sign is misinterpreted when it follows -plist
Posted: 8 years ago 16 déc. 2016, 09:01 UTC−5
Hi Denis,
I checked with some colleagues. They reported that this problem does not occur in the current version, 5.2a.
Hi Denis, I checked with some colleagues. They reported that this problem does not occur in the current version, 5.2a. Best regards, Jeff
