Selecting geometary objecs inside another object
I'm using COMSOL 4.4. Normally after clicking several times, we can select a "buried" domain or boundary (as I did in version 4.3a). But the problem is this way does not work any more now. Is there any "setting" or pamameters affects this function?
2 Replies Last Post 23 juil. 2015, 09:37 UTC−4
Posted: 9 years ago 23 juil. 2015, 08:59 UTC−4
in the newer versions you "scroll" through the pointed entities with the mouse scroll button (not easy on a laptop without scroll button nor mouse but OK ... )
So if you dig into the File - Preferences - Graphics Window Selections (V5) tab you will find a setting: "hover/scroll and left-right click" option to toggle to come back to the "old" way
Hi in the newer versions you "scroll" through the pointed entities with the mouse scroll button (not easy on a laptop without scroll button nor mouse but OK ... ) So if you dig into the File - Preferences - Graphics Window Selections (V5) tab you will find a setting: "hover/scroll and left-right click" option to toggle to come back to the "old" way -- Good luck Ivar
Posted: 9 years ago 23 juil. 2015, 09:37 UTC−4
It works. Thank you a lot!
