volume change
Posted 24 juin 2010, 15:30 UTC−4 Parameters, Variables, & Functions, Structural Mechanics Version 4.1, Version 4.2a 23 Replies
I want to calculate the change in the volume of a deformed body . I am trying to get it using the boundary integration of the total displacement in the post processing option. but i couldn`t be sure whether it is really representing the change of the volume or not. or if there is any other way, please inform me.
tnx in advance
thanks!
can you tell me how the integration(the steps) can be caculated in the post processing?
int (1) dv = V
frame: spatial
the inital volume is by integrating over the the spatial frame, and the final is over the material in V4 or ref frame in V3.5a but you might have to "turn the ref on" in the physics settings) no ?
Why the other way around?
e.g. this is the plot of the surface (because it is 2D) of fsi example in Comsol modeling. Blue is the ref integral and red is the spatial (ALE).
cl.ly/8e860437f5a4a986d442
Or am I misunderstanding something?
You are probably right, I mixing up things too.
In V4 COMSOL has renamed and ordered it better, I have understood, for v4: spatial = Eulerian (X,Y,Z...), material = Lagrangian (x,y,z...) and mesh = on the mesh (Xm,Ym,Zm..), but mesh does not necesarily move as the material, nor as the fluid.
It's the Lagrangian or Euler way of seing things, (the one who likes to swim with the flow and the one only looking on things only from the coast :)
see "Frames" p401 V4 doc: mph_ug.pdf
so from v3.5a its the "reference" frame that has now become "material" frame in V4, I'm i right now ?
the V4 doc is not fully free of references to the "reference frame" yet
I agree this is important to get straight
In FSI cases, when I apply material to the plot, nothing seems has moved (also mesh). Then when I say Spatial it looks the way it should; with all the deformation. So practical understanding of it was
3.5 -------- 4.0
reference --> material
ALE ----> Spatial
mesh? no use so far
And as I'm mostly in structural, hence Lagrangian, that is why I'm getting it up side down w.r.t. to you ;)
I'm working with 3.5. Could you pls help me with following question. I have a 3D subdomain 1 with a hole in the middle, which expands as a result of the pressure on the hole boundaries. I should calculate a growing hole volume at each timestep. If I ntergrate a subdomain 1 over the spatial frame (int(1)dV) at each timestep, it will not include the hole volume. thanks
are you saying you have one domain (a square with a hole) and no mesh in the hole, but pressure boundary condition on the hole, hence hole deformation with time, and you want the hole volume ?
if so, the hole being total volume of square (outside boundary assumed fixed) minus (-) domain "1", and the volume of domain "1" is the integration of operand "1" over the volume (or the surface * thickness in 2D) and in Spatial frame if ST in v4
Thanks a lot,
Regina
if you are using the ALE, and you have no particular physics inside the domain of the hole, you can still mesh it in the ALE section and integrate thereafter witha coupling integration variable of operand "1" and get the "hole" volume to the mesh precision.
One thing that took a loooong time for me to get used to is the implicit COMSOL notation:
you select some domains or boundaries and then you write a formula in GUI field, often with "unusual units" this should be read mathematically, simply (once you know):
SUM_over_selected_Domains_or_Boundaries( int( int( int( Your_formula_for_an_element, dx ), dy ), dz )
In carthesian, if you select some other coordinates mnually you must alo correct the integrationoperands, the COMSOl coordinate transforms, applyes these to getr back to carthesian coordinates.
If you are in 3D structural (smsld in 3.5 or solid in v4) and have a gravity load on two domains/volumes you select the two domains, and type in the GUI field:
rho_smsld[kg/m^3]*9.81[m/s^2]
this means implicitely in COMSOL notations
F[N] = SUM_over_the_two_Domains( int( int( int( rho_smsld_of_each_domain_i [kg/m^3]*9.81[m/s^2] , dx ) , dy ) , dz )
(note the rho_smsld of each domain !) and if you check the units now it is logical ;)
Up to you to correct for the thickness or te loop length 2*pi*r for 2D , 2-Axi respectively
Regina
What I am trying to determine is the volume change of a tank with internal pressure.
How do I go about doing this?
Roy Martin
the volumes are calculated on a mesh, so if your tank is "hollow" and you apply the pressure on the walls it would not work like that ;)
Workaround: you add the internal volume, as a "vacuum" no force item and then calculate the volume
Ok, I have an internal volume and set up the volume integration for the domain representing the internal volume to evaluate an expression of 1.
Now, is the calculated volume the deformed volume or the original volume?
Is there a way to calculate both in comsol so that I can get the difference? Rather than try to compare a comsol mesh volume to a solidworks solid volume...
Roy
in v4.1 and solid physics, you have now by default the "deformed mesh on" wich means that the spatial frame (defomed one) and the material fram (original ones) are different. Make 2 operators, one for the spatial frame, one on the reference frame, and integrate the same domain (or boundary) after having solved, or at least updated an existing solution. Then you shoudl get the different volumes, before - after
What I did:
created a volume integration of the domain of interest with an expression of 1. this calculates the volume of the domain. The data set is the solution of interest.
Then, in the solution to which the date set points, change the Frame from Spatial to Material or Mesh. With spatial being the deformed geometry and material/mess being the reference (original) geometry.
Solve the integration for both frames, take the difference, and I get the volume change.
correct me if I stated anything wrong.
Another related question. In trying different things early, I came accros the variable for volumetric strain. If this variable is used as the expression in the volume integration, the result is very close to the difference calculated above if the Frame used is Spatial (deformed) and almost the same if the Frame used is Material/Mesh. Is this coincendence, or what should happen?
Thanks for all the help,
Roy
well done, welcome the the frame game, this is more usuall in fluidics, buit solid stress strain, is in ome way "flow" with specific conditions. So now yu know eveything about Euler and Lagrange ?
By the way in V3.5 one must turn on the deformed frame in the Physics tab for solid structural.
For the rest of your coment I believe so, but I would have to take a look at the equations underneath (turn on the equations in COMSOL, I find it very useful) so you could as well look it up too ?
Just trying to understand regarding volume .
I am implementing as follows:
operator name intop1
source selection boundary, selection "inner_surface"
variable
name: vol, expression intop1(1)
Does this mean vol represent the volume enclosed by "inner_surface"?
Susant
1) In which frame ? you have also a frame field in the operator definition spatial or Materil (or mesh ?)
2) volume are on domains, not on boundaries, there is something I'm not following, or not understand
I am using 4.2a and I am trying to calculate the volume of my deformed solutions. I have tried the things suggested in this thread, but I cannot get it to work. My model uses the Solid Mechanics module and the PDE module to model poroelasticity in the brain.
I can see the deformation in my plots, and even though I have tried all frame types in my volume integration, the number I get for the volume remains the same as the non-deformed geometry no matter what I do. I am trying to see how volume change as a result of prescribed displacement on the surface affects pressure, but for this I need to know the magnitude of volume change.
I am wondering if, perhaps, there is some check box I need to check or uncheck to make this work. Does it make a difference that I use an imported mesh versus one generated from a geometry?
Carolyn.
I believe that is because things has canged in 4.2a w.r.t. earlier, due to too many people being confused by the frames.
If you want to get the deformed volume, try turning ON the non-linear geometry tick in the SOLVER node, resolve sour moel then integrate the domain with the integrand of "1" over the SPATIAL frame x,y,z (not the Material frame X,Y,Z)
I believe this shold do it in v4.2a
the best is to try it out on a simple model i.e. a "soft" volume in 3D solid with a gravity body load agains a fixed boundary
