My guess is that the 0.1 um is still applied so the plane will not move further regardless of how much extra pressure you apply. You have to be careful when you switch from applying displacement AND force/pressure to the same boundary. If possible avoid it and reformulate your problem such that you only apply pressure or displacement, and in many problems that is doable. If not, then make sure you disable the prescribed displacement at the same time you apply the pressure.
Nagi Elabbasi
Veryst Engineering
I think I try to simulate exactly what you described ;)
I model a contact between a deformable and a rigid body in a pressurized chamber (2D model). A load results from the contact of both bodies. Where there is no physical contact between the bodies the chamber pressure must be applied.
I do not want to use Contact Pairs. Therefore, I just model the deformable body and I use BC to account for the contact with the rigid body. I see two approaches:
a) Prescribed Displacement BC: This works like a charm however I am using both Prescribed and Load BC. One contributes to each other.
b) Pressure Load BC: I define a piecewise pressure function dependent on the resultant gap between the bodies (H). I assume that contact between bodies occurs when the H<1 micrometer.
1. When H>1 micrometer I apply the pressure of the chamber.
2. When H< 1 micrometer I define a Contact Pressure function also dependent on H. The smaller the H, the higher the pressure to be applied.
Would you suggest another way to do it?
Would you suggest modeling both bodies and using contact pairs?
Thanks in advance ;)
[QUOTE]
Nagi Elabbasi
Veryst Engineering
[/QUOTE]
b) Pressure Load BC: I define a piecewise pressure function dependent on the resultant gap between the bodies (H). I assume that contact between bodies occurs when the H1 micrometer I apply the pressure of the chamber.
