3 oct. 2013, 12:14 UTC−4
I just simplified my structure to test the stuff with a constant temperature of +4°C. It's really strange because I get a maximum temperature of -12°C, so not even my boundary with my constant temperature has the +4°C. I already used a very fine mesh.
I atteched the file, maybe someone can tell me what I make wrong!?!?!?
thx
thx
4 oct. 2013, 09:29 UTC−4
I just checked it with an older version of COMSOL (3.5). When I set there a constant temperature at a boundary this temperature also appears in the result (direct on the boundary, of course ;-) )!!!
So PLEASE can anyone tell me what I make wrong with version 4.3 ?!?!?!?!?
thx
thx
7 oct. 2013, 01:44 UTC−4
I tested your model and noticed same problem. This has maybe something to do how Comsol handles wall functions. I don't know is this right or wrong but if you want to get rid of this use " Low-Reynolds k-epsilon" turbulence flow. This will give you more accurate results.
Best regards
Tero Hietanen
Best regards
Tero Hietanen
10 oct. 2013, 11:04 UTC−4
@ Tero:
it works with Low-Reynolds k-epsilon. But when i investigate my real problem with a boundary heat source my results are a little bit strange.
@ all:
To be sure I can use the turbulent model I increased the length of my plate to 1m, thus I get a Reynolds number of 3.2491 * 10^6. For that length and an area of 1 m^2 I need a power of 4349 W to keep my plate at +4°C (inlet @ -30°C and 45m/s).
When I simulate it the end of my plate is at a temperature of ~ +240°C and the front is at ~ -20°C. So my question is, is it possible to validate my calculations. Because it is a logical result that the end of the plate is the warmest spot and the end the hottest. Maybe it is juast a meshing problem!?!?
One problem that I have is I can not use the COMSOL implementet material for AIR. When i try to use it I get different error massages or the error did not convergate. Currently I use constant (mean) values for air in the region of -30°C to +10°C.
I atteched the file, maybe someone would be so kind and have a look at it. I'm trying to verify my results scince almost one week :-(.
thx
@ Tero:
@ all:
thx
11 oct. 2013, 05:17 UTC−4
Hi Matthias,
You have used Turbulent flow and Heat transfer by separated physic. Instead of this, use Isothermal Flow where turbulent flow and heat transfer are connect with each other. Also check what values you get to "dimensionless distance to cell center". This should be low as 0.5.
This may help you:
www.comsol.com/blogs/which-turbulence-model-should-choose-cfd-application/
Best regards
Tero
Hi Matthias,
This may help you:
http://www.comsol.com/blogs/which-turbulence-model-should-choose-cfd-application/
Best regards
Tero
11 oct. 2013, 10:57 UTC−4
Hi Tero,
thank you for the link. I already read it but i jumped over the last paragraph. Thank you very much!!!!!!
Can someone tell me what the "dimensionless distance to cell center" is, and how is it calculated? I couldn't find anything on the web or even at the COMSOL website. And is there a possebility to set this value before I start the simulation?
I still have the problem that I can't use the COMSOL implemented air - material. I get error massages like "Attempt to evaluate non-integral power of negative number". How can I fix that??
BR
Hi Tero,
BR
17 oct. 2013, 06:54 UTC−4
Hi guys,
I'm still searching for a definition of the dimensionless distance to cell center. Can someone tell me how it is calculated!?!?!?
thx
Hi guys,
thx
