coil above ferrite bars
Hi all
I want to simulate the structure of two coils of first coil is placed on ferrite bars and second coil is simple coil which both are separated by distance of 10 cm . I tried to construct the coil above ferrite bars bars , but the bars are just not below the coils and it just going above the coil and i use phase shift by taking square .How to make a proper geometry for primary coil lie above ferrite bars and secondary coil at a distance of 10 cm, and i dont know how to make a secondary coil at distance . I am sending my model how i made geometry of coil .But its not good. So please suggest me to design good geometry for this case
kishore Naik Mude
2 Replies Last Post 17 sept. 2013, 02:45 UTC−4
Posted: 1 decade ago 16 sept. 2013, 15:05 UTC−4
kishore,
You are using 2D geometry. I would rather use 3D space to build geometry.
Sergei
kishore, You are using 2D geometry. I would rather use 3D space to build geometry. Regards, Sergei
Posted: 1 decade ago 17 sept. 2013, 02:45 UTC−4
I am trying to use 3 D geometry
kishore Naik Mude
Thanks I am trying to use 3 D geometry -- kishore Naik Mude
