To find the temperature difference between two boundaries
I have built a model and found the temperature distribution over its surface. I want to plot over time the difference between the temperatures at two points over the surface. Please assist me in this regard.
2 Replies Last Post 6 août 2014, 06:50 UTC−4
Posted: 1 decade ago 7 août 2013, 02:08 UTC−4
You can do this using a Join data set:
- Results > Data Sets: Add a Cut Point and enter the first point's coordinates.
- Results > Data Sets: Add a Cut Point and enter the secondt point's coordinates.
- Results > Data Sets: Add a Join and change Data 1 and Data 2 to point to the two cut points.
- Results: Add a 1D Plot Group and change its Data set to the Join data set.
- Add a Point Graph to the plot group and enter the expression that you want to plot.
By default, the Join data set evaluates the difference between the two data sets its points to, so this gives you the plot you want.
You can do this using a Join data set: - Results > Data Sets: Add a Cut Point and enter the first point's coordinates. - Results > Data Sets: Add a Cut Point and enter the secondt point's coordinates. - Results > Data Sets: Add a Join and change Data 1 and Data 2 to point to the two cut points. - Results: Add a 1D Plot Group and change its Data set to the Join data set. - Add a Point Graph to the plot group and enter the expression that you want to plot. By default, the Join data set evaluates the difference between the two data sets its points to, so this gives you the plot you want.
Posted: 1 decade ago 6 août 2014, 06:50 UTC−4
Dear Gunnar Andersson,
I have modeled a laser beam welding. it is predicting the temperature distribution. i want the comsol to find the time that each node with the temperature above 810 degree Celsius , experiences between 800-500 degrees during cooling.
can you help me with that please?
kind regards
reza
Dear Gunnar Andersson, I have modeled a laser beam welding. it is predicting the temperature distribution. i want the comsol to find the time that each node with the temperature above 810 degree Celsius , experiences between 800-500 degrees during cooling. can you help me with that please? kind regards reza
