How to export data on selected points
Alberto Garcia-Cristobal
Hi All
I have 1D line plot and I want to export the data of the plot on selected grid points, not the entire plot. Any Idea or suggestion would be of great help.
A.
3 Replies Last Post 16 juil. 2013, 09:52 UTC−4
Posted: 1 decade ago 14 juil. 2013, 16:41 UTC−4
I believe the answer to your question is:
Right click in "Derived Values"
choose "Point Evaluation"
Select the points and the expression
Evaluate
Also you can do in Matlab with the command mpheval or mphinterp
cheers,
Felipe BM
I believe the answer to your question is: Right click in "Derived Values" choose "Point Evaluation" Select the points and the expression Evaluate Also you can do in Matlab with the command mpheval or mphinterp -- cheers, Felipe BM
Posted: 1 decade ago 15 juil. 2013, 08:21 UTC−4
Dear Felipe
Thank you for your suggestions. I tried using 'Derived value' and then "Point Evaluation". In this way, only some (restricted ) points are available to choose.
By now I solved the problem using the following procedures.
1st. click 'Export'
2nd choose 'data'
- choose 'Grids' from ' points to evaluate in ' option
-finally define the grid (The starting point,,,grid gap and final points)
A.
Dear Felipe Thank you for your suggestions. I tried using 'Derived value' and then "Point Evaluation". In this way, only some (restricted ) points are available to choose. By now I solved the problem using the following procedures. 1st. click 'Export' 2nd choose 'data' - choose 'Grids' from ' points to evaluate in ' option -finally define the grid (The starting point,,,grid gap and final points) Regards, A.
Posted: 1 decade ago 16 juil. 2013, 09:52 UTC−4
Way to go!
Que bueno! :)
cheers,
Felipe BM
Way to go! Que bueno! :) -- cheers, Felipe BM
