Hello Anand N
30 avr. 2013, 11:44 UTC−4
Start by simulating the step index fiber (find it at the model gallery).
Then you can start by modifying that model and inserting the air-holes. Finally you can go an insert the liquid crystals.
cheers,
Felipe BM
cheers,
Felipe BM
1 mai 2013, 01:40 UTC−4
Thank you Mr. Felipe for your response......
I have tried simple models....
I am having doubt regarding creating PML layers and boundary conditions...
Is creating a PML necessary thing?
I heard from a friend that it is enough to keep 'scattering boundary conditions' options instead of PML.
1 mai 2013, 13:26 UTC−4
you can always start with 'scattering boundary conditions'. But generally, PMLs perform better.
2 mai 2013, 08:18 UTC−4
It depends on how important are the radiation losses for you.
In case you do not need to know precisely the radiation losses, then I will go with the Comsol's PML just to prevent spurious reflections to have an influence on your results.
cheers,
Felipe BM
cheers,
Felipe BM
3 mai 2013, 21:30 UTC−4
Thank you Mr. Felipe ...
I will proceed with the PML layer itself :)
25 juin 2013, 23:16 UTC−4
Hi Anand, can you help me to find the effective index of PCF? how to plot the effective index against wavelength
thanks!
thanks!
9 déc. 2013, 09:29 UTC−5
You can obtain the effective index equation from the top of the profile obtained after simulation.
Uday Bangavadi Munivenkatappa
5 mars 2014, 13:49 UTC−5
HI anand,
Could you please explain .. how u got the effective index profile. I am completely struck over there. IT would be of great help.
Thanking you,
Uday
HI anand,
Thanking you,
Uday
5 mars 2014, 23:05 UTC−5
Hi Uday,
Have you obtained the intensity profile for your model?
If so, you can see your effective index above it. The real part corresponds to the effective index.
It will correspond to the first solver parameter.
You can see the other values too from the post processing menu.
Anand
P.S. I am still a beginner in COMSOL modelling.
Hi Uday,
Anand
