pulsed concentration
I would like to give a pulsed concentration to my model. Therefore I created a rectangle function rect1.
Then I would like to declare my concentratin c_in as variable as rect1(t[1/s])*0.1 Unfortunately comsol tells me that rect 1 is an unknown variable.
How can I solve this problem?
Kind regards,
Sarah
2 Replies Last Post 6 mars 2013, 02:42 UTC−5
Posted: 1 decade ago 6 mars 2013, 01:01 UTC−5
where did you define the rect1 ?
in the "Global definitions - ..." or in the "Model - Definitions - Functions - rect" ...
and did you solve first and ten define your function ?, if so do an "Study - right click - Update Solution" first
Defining the solution is done high up in the node tree, compiling and getting it into the data base (Data Set) is done by the solving process
Hi where did you define the rect1 ? in the "Global definitions - ..." or in the "Model - Definitions - Functions - rect" ... and did you solve first and ten define your function ?, if so do an "Study - right click - Update Solution" first Defining the solution is done high up in the node tree, compiling and getting it into the data base (Data Set) is done by the solving process -- Good luck Ivar
Posted: 1 decade ago 6 mars 2013, 02:42 UTC−5
Thank you, after updating the solution its working!
