Volume Integral
comp1.intop1(k_simp*ht.gradTmag^2) what is meaning of [ ht] in this equation ?
RahulK
2 Replies Last Post 27 nov. 2024, 02:26 UTC−5
Magnus Ringh COMSOL Employee
Posted: 5 months ago 26 nov. 2024, 07:38 UTC−5
Hi Rahul,
ht is part of the "scope" for the variable. It's the default short name for a Heat Transfer in Solids interface, so it signifies that this gradTmag (the temperature gradient magnitude) is the one computed for that specific physics interfaces. If you would have a second Heat Transfer in Solids interface, its default short name would be ht2, and its variable for the temperature gradient magnitude would be ht2.gradTmag.
Magnus
Hi Rahul, `ht` is part of the "scope" for the variable. It's the default short name for a Heat Transfer in Solids interface, so it signifies that this `gradTmag` (the temperature gradient magnitude) is the one computed for that specific physics interfaces. If you would have a second Heat Transfer in Solids interface, its default short name would be `ht2`, and its variable for the temperature gradient magnitude would be `ht2.gradTmag`. Best regards, Magnus
Posted: 5 months ago 27 nov. 2024, 02:26 UTC−5
Respected sir, Thank you very much
RahulK
Reply
