Failed to evaluate variable Jacobian
I simulate the rib waveguide with the sio2 substrate and material of the core Er:Ta2o5
i define the lambda=1550nm in global definition>parameters, and in the step 1:frequency domain:c_const/lambda
in the electromagnetic wave field i define 2 port for the core(Er:Ta2o5):
port 1:port type :rectangular and wave excitation is on
port 2: port type :rectangular and wave excitation is off
mode type is TE,mode number :10
when i want to simulate,i am getting the following error:
Failed to evaluate variable Jacobian.
- Variable: mod1.emw.tE0modex_2
- Geometry: 1
- Boundary: 7
do you know how to fix this problem?
Thanks in advance for the comments
Michael
7 Replies Last Post 21 janv. 2013, 14:27 UTC−5
Posted: 1 decade ago 18 janv. 2013, 08:58 UTC−5
try with a different name for lambda, such as lambda_1
Posted: 1 decade ago 18 janv. 2013, 12:40 UTC−5
Hi Samuele
I do it but it does'nt worked. do you have other suggestion?
Thanks in advance
Hi Samuele I do it but it does'nt worked. do you have other suggestion? Thanks in advance
Posted: 1 decade ago 18 janv. 2013, 14:55 UTC−5
Most likely your problem is with boundary condition at boundary 7. It's hard to tell how to fix it without knowing what boundary 7 is.
Posted: 1 decade ago 19 janv. 2013, 08:19 UTC−5
Hi Alexander
Thanks for your response
I send you the schematic file and marked the 7 boundary.
Thanks in advance
Hi Alexander Thanks for your response I send you the schematic file and marked the 7 boundary. Thanks in advance
Posted: 1 decade ago 21 janv. 2013, 12:42 UTC−5
What's the BC on boundary 7?
Posted: 1 decade ago 21 janv. 2013, 13:16 UTC−5
Hi Alexander
sorry, what is the BC ?
Hi Alexander sorry, what is the BC ?
Posted: 1 decade ago 21 janv. 2013, 14:27 UTC−5
BC = Boundary Condition in this case value set by a "boundary node" in your physics tree
Hi BC = Boundary Condition in this case value set by a "boundary node" in your physics tree -- Good luck Ivar
