Hello David964
9 years ago
20 mai 2016, 11:32 UTC−4
HELLO DAVID
in ur model u have not shown cladding.....only core is there.
what diameter off cladding u r taking...send me ur model.....i will guide you.
waiting for ur reply
HELLO DAVID
Walter Frei
COMSOL Employee
9 years ago
20 mai 2016, 11:38 UTC−4
Regarding optical waveguide modeling in the full-wave regime, please see the following example:
www.comsol.com/model/dielectric-slab-waveguide-14709
You may also be interested in the beam-envelopes formulation, as shown here:
www.comsol.com/model/mach-zehnder-modulator-15061
www.comsol.com/model/optical-ring-resonator-notch-filter-22221
https://www.comsol.com/model/dielectric-slab-waveguide-14709
https://www.comsol.com/model/mach-zehnder-modulator-15061
https://www.comsol.com/model/optical-ring-resonator-notch-filter-22221
8 years ago
11 oct. 2016, 08:31 UTC−4
I am trying to simulate the same model as you have attached before the Notch Filter, but I am trying to determine the parameters of the radius and the distance for other materials, I am doing a parametric sweep in the radius and in the distance between the waveguide and the microring resonator, and the problem appears when I try to plot the transmission in a surface plot with this two parameters.
Could you help me, please?
Often appears the next message:
No solution found for outer solution number 1000.
