Using multiple load cases in a frequency analysis/sweep study
Hello.
I would like to perform a frequency sweep vibroacoustic analysis of a vibrating cantilever plate. I can create a number of different loadings, and then analyse each loading using a separate analysis run. The solution is computationally expensive to set up, and it would save a lot of time if I were able to solve for each load case (right-hand side of the system of equations) once the main matrix is computed.
Although this is something that is possible when performing a static stress analysis, I can't seem to find a way of doing the same thing while performing a frequency sweep.
Is it possible to analyse multiple load cases when performing a frequency sweep? If so, can some tips be provided as to the methodology that needs to be followed?
Thanks for any help that can be provided.
1 Reply Last Post 7 mai 2024, 03:02 UTC−4
Posted: 10 months ago 7 mai 2024, 03:02 UTC−4
You do exactly the same thing as for stationary analysis. Attach load groups to the loads and define the load cases in the Study Extensions section of the Frequency Domain study step.
Henrik Sönnerlind
COMSOL
You do exactly the same thing as for stationary analysis. Attach load groups to the loads and define the load cases in the **Study Extensions** section of the **Frequency Domain** study step.
