Recalculate without re-meshing?
Posted 26 févr. 2024, 22:44 UTC−5 Mesh, Studies & Solvers, Physics Interfaces Version 6.2 2 Replies
Hi all,
I'm sure there's a way to do this, and I've been searching, but cannot figure out the right keywords to figure it out.
I have a model for which I'm sweeping a few different geometric parameters, which makes the simulation quite long. I need to run this same set of sweeps twice, one with an applied voltage at one location, and the second with it at a different location.
Currently, I have this set up with a single component geometry and two separate physics setus. The physics setups are identical other than the placement of the applied voltage. Then I have three studies defined: a parametric sweep for each physics, and then a third study that just runs the other two sequentially.
In this setup, the same set of meshes are generated twice, once for each of the parametric sweeps. But this seems quite silly to do, since the meshes are the same. Is there a way to either save the meshes and re-use them in the second sweep, or just "update" the first sweep after it's done with the re-applied voltage, or maybe something else to cut down on the time? There must be a way to not need to recalculate all the meshes again (hopefully).
Thanks.
