Add gaps along a parametric curve
Hi folks, we have an parametric curve with the follow settings:
Parameter: Name: Minimum: Maximum:
Expressions: xw: yw:
The curve is sweeped with an rectangle 1x4mm width/height to build a flat spiral and is divided into two work planes parametric curve/rectangle.
Now we would like to add a 1mm gap every 15mm along the entire parametric curve, and if possible also keep the shape/size.
We hope someone here can help us..
2 Replies Last Post 18 févr. 2024, 14:11 UTC−5
Posted: 9 months ago 18 févr. 2024, 02:28 UTC−5
Maybe multiply with some if-statement? xwif("(s>q)(s<q)",0,1), with q somehow representing the gabs?
René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
Maybe multiply with some if-statement? xw*if("(s>q)*(s
Posted: 9 months ago 18 févr. 2024, 14:11 UTC−5
How and where do I set the additional q parameter?
And where do I insert the if-statement with the formula?
We are completely new to COMSOL so step by step would be nice.
How and where do I set the additional q parameter? And where do I insert the if-statement with the formula? We are completely new to COMSOL so step by step would be nice.
