How to add both rotation and Translation simultaneously for a geometry.
Recently, I creat a geometry with helix shape. I need helix rotate with its central axis, so the rotation movement will be transformed into translation(forward) due to helical shape. Now with the Moving Mesh Interfaces, I can only realize the helix rotate with its central axis,but it not translation, only stay the original place and rotation.
In addition, I also try the prescribed deformation, with dx = cos(2pit1[Hz]) dy = sin(2pit1[Hz]) dz = t*1[m/s] But, this a whole tranlation without rotation with its central axis.
So, could u please give me some suggestions about how to apply both rotation and translation for a helix shape, and with its rotation with its axis, it can realize translate forward.
Thank you for your help and looking forward to your reply.
Best regards Hou
1 Reply Last Post 11 oct. 2023, 14:56 UTC−4
Posted: 2 years ago 11 oct. 2023, 14:56 UTC−4
Hou,
I think the expressions for the prescribed deformation are not complete. Shouldn't the x and y movement comprise the radius (e.g. sqrt(x^2 + y^2) and the z movement should comprise the pitch of the helix?
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hou, I think the expressions for the prescribed deformation are not complete. Shouldn't the x and y movement comprise the radius (e.g. sqrt(x^2 + y^2) and the z movement should comprise the pitch of the helix? Cheers Edgar
