membrane under stress
Hi!
I am calculating the eigen frequency of Si3N4 membrane. The membrane is 2mm * 2mm and the thickness is 50 nm. This membrane is fixed to the frame. Therefore, I fixed the four edges with fixed constraints. At this time, the stress applied to the membrane is 1GPa, but I do not know how to apply this to COMSOL. I've tried applying tension to the edge with a boundary load, but this doesn't change the result with or without tension. *Maybe I'm a beginner and don't know the basics well.
thank you!
1 Reply Last Post 10 sept. 2023, 05:47 UTC−4
RAJA KUMAR Acoustics & Vibration
Posted: 1 year ago 10 sept. 2023, 05:47 UTC−4
Hello, use initial stress
even this doesnot help mail me, may be i can help. iamrajakr@gmail.com
iamrajakumar@iitkgp.ac.in
iamrajakr@gmail.com
Hello, use initial stress even this doesnot help mail me, may be i can help. iamrajakr@gmail.com
