error in stationary solver
I am modeling 3d capacitive accelometer , during simulation process i am getting the error :"out of memory in stationary solver". kindly can any one help me out .
1 Reply Last Post 20 oct. 2012, 06:37 UTC−4
Posted: 1 decade ago 20 oct. 2012, 06:37 UTC−4
you need to see how to simplify your model (less mesh, use symmetry ..., or the ther way buy more RAM or a larger computer. But check if you do not need a cluster, all depends how many DoF's you have selected, each require at least some 32-64 bits of RAM
Hi you need to see how to simplify your model (less mesh, use symmetry ..., or the ther way buy more RAM or a larger computer. But check if you do not need a cluster, all depends how many DoF's you have selected, each require at least some 32-64 bits of RAM -- Good luck Ivar
