Exporting data for multiple Cut planes
Posted 20 août 2012, 09:43 UTC−4 Results & Visualization Version 4.0, Version 4.2, Version 4.2a 3 Replies
Hi all,
I'm modeling a mixer and I would like to export concentration profiles at different cut-planes along the channel. I can do a single cut plane export with:
Defining: Data Sets -> Cut Plane - then...
... Export -> Data -> Data set -> Output...
How can I do the same for multiple cut planes - when I try to use the same procedure (under Data Sets -> Cut Plane ...) defining multiple Cut planes via 'Additional parallel planes' options it doesn't work. For the concentrations I get only NaN-s.
Thank you in advance for your generous help!
Izidor
Izidor
3 Replies Last Post 13 mars 2015, 10:26 UTC−4
