Acoustic Power/Intensity - Monopole source next to rigid sphere
Posted 5 nov. 2021, 17:53 UTC−4 Acoustics & Vibrations Version 5.6 3 Replies
I'm attempting to quantify the total acoustic power in different regions of a 1m spherical boundary that surrounds a smaller rigid sphere ("head") next to a monopole point source ("speaker"). I plan to use this as a metric of directivity/scattering.
I defined a monopole point source of strength 1W and calculated the total acoustic power by integrating Intensity over the surface of the 1m spherical boundary.
When I remove the "head" and have just the point source, I calculate the power on the surface of the 1m sphere to be 1.00W. However, when I add the rigid "head" into the model, I calculate various total power results for different frequencies ranging from ~0.75-1.25.
I'm somewhat new to COMSOL, however, I have gone over this for several days and can't figure out why I'm not consistently getting 1.00W (or close to) when I place a rigid surface next to the point source.
I have created both 3D and 2D models, and looked at various methods of surface integration that all produce similar results.
I just noted this clarification of monopole source strength in the help:
When Power is selected, specify the source’s reference RMS strength by stating the power it radiates. In a homogeneous medium, the specified power is obtained (the reference), but with other objects and boundaries present the actual power is different.
Might this explain what I'm seeing? Regardless, I don't understand how that jives with conservation of energy.
I appreciate any help. -Michael
