Is it possible to apply global von-Mises stress constraint in Topology Optimization?
I have an objective of increasing stiffness/ reducing strain energy.
But my main constraint is not about mass (how much mass I want to retain), but I want to put constraint over the maximum global von-Mises stress. Is it possible to set a problem like this in COMSOL?
3 Replies Last Post 28 janv. 2022, 03:58 UTC−5
Posted: 4 years ago 28 juil. 2021, 16:16 UTC−4
this may work with a pointwise constraint. Another option may be to set up a maximum operator maxop1 in the nonlocal couplings and use maxop1(vanMises) in a global contraint.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi, this may work with a pointwise constraint. Another option may be to set up a maximum operator maxop1 in the nonlocal couplings and use maxop1(vanMises) in a global contraint. Cheers Edgar
Posted: 4 years ago 30 juil. 2021, 05:16 UTC−4
Hello Edgar,
Thanks for the reply. I tried both the options you suggested.
I found "point-sum inequality constraint" to be working very nicely in general for all kinds of constraint but solver is not following "Global inequality constraint". I mean the results are not as expected when I used global constraint. I applied it the way you suggested, from non-linear coupling by choosing maximum operator maxop.
Do you have any other sugestions for applying a global constraint?
Hello Edgar, Thanks for the reply. I tried both the options you suggested. I found "point-sum inequality constraint" to be working very nicely in general for all kinds of constraint but solver is not following "Global inequality constraint". I mean the results are not as expected when I used global constraint. I applied it the way you suggested, from non-linear coupling by choosing maximum operator maxop. Do you have any other sugestions for applying a global constraint?
Posted: 3 years ago 28 janv. 2022, 03:58 UTC−5
maxop is not differentiable, you need to make an integral over the domain of the VM stress to the power p. This makes a continuous p-norm, which is an approximation of the max function for p --> infinity.
