Bandgap Analysis of Photonic Crystal(2D periodic) in 3D model
Hello everyone,
I try to work from the 2D model (bandgap analysis of photonic crystal in model library of 3.5a) to the 3D case.
I use the same parameters except for the height of 3D model is 100nm and the global function is 4.5e15-nEz. Because I found nEz in 3D model is around 4.5e15. Fortunately, I got the same results with 2D model.
I wonder what's the physical meaning of global function 1-nEz and whether the function in 3D model is right. If not, how can I calculate bandgap of PC(2D periodic) in 3D model?
Ray
1 Reply Last Post 3 avr. 2017, 16:28 UTC−4
Hello Zhang Ray
Posted: 8 years ago 3 avr. 2017, 16:28 UTC−4
Hi, Ray,
Did you solve this problem in 3D model? I encountered the same problem...... Could you help me? Thanks in advance.
Best
Tianjing
Hi, Ray, Did you solve this problem in 3D model? I encountered the same problem...... Could you help me? Thanks in advance. Best Tianjing
