Fine Meshing Around Work Plane
I have a structure containing a work plane where a resonator is placed. I want to be able to make the mesh in and around the work plane very fine, while leaving the rest of the model using relatively coarse meshing. I've tried using virtual operations with mesh domain control, but this gets rid of the work plane. Is there a way to implement this, while keeping the contents of the work plane?
1 Reply Last Post 24 mars 2021, 18:26 UTC−4
Posted: 4 years ago 24 mars 2021, 18:26 UTC−4
You could partition the object with the workplane, select the boundary, and do a fine triangular mesh on the boundary.
