Boolean function that is 1 inside a geometric entity and 0 outside
Logan Bishop-Van Horn
Does anyone know if there is a boolean function that is 1 inside a geometric entity and 0 outside which can be used in variable/expression definitions? I am looking for something like
inside_geom(x, y, z, geom) -> 1 if (x, y, z) is located inside geom, 0 otherwise
1 Reply Last Post 1 mars 2021, 05:18 UTC−5
Posted: 4 years ago 1 mars 2021, 05:18 UTC−5
If you mean 'inside a geometric entity' as in 'located inside domain 17', then you can use the expression dom == 17. What 'dom' means depends on the context, so it can be a domain, boundary, or edge.
Henrik Sönnerlind
COMSOL
