Question in Computing and Controlling the Volume of a Cavity
Posted 1 déc. 2020, 02:43 UTC−5 Structural & Acoustics, Fluid & Heat, Acoustics & Vibrations Version 5.3a 0 Replies
Dear All,
In this discussion: https://www.comsol.com/blogs/computing-controlling-volume-cavity/
What are the changes which need to be done in addition to adding the global equation if I'm using water or any liquid ?
Like: should I change the pressure equation ?
Also,
I'm using 3D model not 2D; what I should change in the integration operator ? should I leave the coordinate as x and nx ? or should be changed ?
Thanks!
Hello Abdelrahman Ali
