Axis range
I am using Comsol 3.5 right now and I wondered if there is any way to define the range of Y-axes when doing cross section plotting.
Because right now my Y axis change from (2.4545e-10 to 2.4545e-10) as you ca see it is not possible to follow the changes. So for example i want to be able to see 6 digits after the point or go to range of e-11.
Anybody have any idea on this?
Best
Bahar
3 Replies Last Post 23 mars 2012, 15:22 UTC−4
Posted: 1 decade ago 23 mars 2012, 14:20 UTC−4
You can plot your variable minus 2.4545e-10. Then you will see extra digits. Otherwise I don't know if it's possible at all.
Posted: 1 decade ago 23 mars 2012, 15:05 UTC−4
It might be helpful for some plots but for example when we use "Global variable plot" we do not have any control to change Y-Axis. So I can not plot for (Parameter- 2.4545e-10)
Posted: 1 decade ago 23 mars 2012, 15:22 UTC−4
Another option that exists in 4.2a is to change "Precision" under global COMSOL options (Options-Preferences). I don't remember if there is something similar in 3.5.
