Perfect Electrical Conductor Problem
I'm having a problem where when I draw a geometry all of the boundaries are automatically selected as perfect electrical conductors and I can't change this. I've been trying to follow along with the RF power transfer example and I can't because it makes everything a PEC. What's going on?
1 Reply Last Post 29 avr. 2020, 15:42 UTC−4
Posted: 5 years ago 29 avr. 2020, 15:42 UTC−4
Louis,
PEC is the default. You can add, e.g. an impedance BC node, select boundaries and they will be overridden in the default PEC node.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Louis, PEC is the default. You can add, e.g. an impedance BC node, select boundaries and they will be overridden in the default PEC node. Cheers Edgar
