Determining area and volume of axis-symmetric object
Hi!
I'm modeling a membrane as an axis-symmetric object. Can you tell me how I can determine the area and the volume of the upper side of the deflected membrane?
I understand there have to be integration-nodes for this tasks in the postprocessing. But where?
Christian Kelb
2 Replies Last Post 20 janv. 2012, 17:01 UTC−5
Posted: 1 decade ago 20 janv. 2012, 09:37 UTC−5
you can take the volume integration with parameter as 1 with dataset "revolution" 0 to 360 to get the volume
Posted: 1 decade ago 20 janv. 2012, 17:01 UTC−5
in 2D axis-symmetry, when you integrate over an edge and use the integrand 2*pi*r you get the revolved surface, but if you define your integration operator, you can check the surface to volume box, then the 2*pi*r are automatically added. Check the units to be sure you have it right.
There are several threads on the forum about this
Hi in 2D axis-symmetry, when you integrate over an edge and use the integrand 2*pi*r you get the revolved surface, but if you define your integration operator, you can check the surface to volume box, then the 2*pi*r are automatically added. Check the units to be sure you have it right. There are several threads on the forum about this -- Good luck Ivar
