Resolution of Comsol Simulations
I am just wondering what is the minimum resolvable changes in result that we can correctly detect in Comsol.
I would like to change some of the conditions, and study their effect on resonance frequency of cantilever. However, I don't know how to validate the results.
At some conditions, I expect very small change (e.g. 0.001% of the eigenfrequency) in some conditions. I am mainly concerned whether this much resolution is achievable or not.
I appreciate any thoughts.
Som
1 Reply Last Post 6 janv. 2012, 06:26 UTC−5
Posted: 1 decade ago 6 janv. 2012, 06:26 UTC−5
you have the numerical resolution of binary number "eps" (try to look at its value in the Parameter section with a
myvar = eps
But that is seldom the limiting one for a full model, mostly it is mesh density related (and shape function value) and then most important: Solver Relative & Absolute Tolerances (both might not apply for all solvers)
My way is to double the mesh and look at the effect, this gives a good first order indication
Hi you have the numerical resolution of binary number "eps" (try to look at its value in the Parameter section with a myvar = eps But that is seldom the limiting one for a full model, mostly it is mesh density related (and shape function value) and then most important: Solver Relative & Absolute Tolerances (both might not apply for all solvers) My way is to double the mesh and look at the effect, this gives a good first order indication -- Good luck Ivar
