mode analysis in ring waveguides
Posted 14 déc. 2011, 07:51 UTC−5 RF & Microwave Engineering, Wave Optics, Modeling Tools & Definitions, Parameters, Variables, & Functions Version 4.2, Version 4.2a, Version 5.1, Version 5.2 3 Replies
using the 2D-axisymmetric space dimension and the RF-module, I'm doing a mode analysis of a ring waveguide, where the diameter d of the ring (not the waveguide itself!) is in the order of 100e-6 m, i.e. the radius r_ring approx. 50e-6 m.
Since the problem can be represented in cylindrical coordinates (r, phi, z), and the structure does not depend on phi, it is sufficient to define the cross section of the waveguide and tell Comsol to use the appropriate space dimension; this is exactly what the mentioned 2D-axisymmetric simulation does.
The waveguide is made of a core with refractive index n_core, and some cladding with n_clad, with n_clad < n_core to allow light to propagate. As an example, n_clad = 1.5 and n_core = 2.0.
The mode analysis works fine, but I've got an issue with the exact definition of the effective refractive index n_eff, which, in usual linear waveguides, usually is some value between n_clad and n_core. As an initial guess for the mode solver, it is helpful to provide some value in the vicinity of the expected n_eff.
However, in this ring structure, things are different.
I only get results when I provide a value much smaller than n_core: It turned out that a value in the order of (n_core * r_ring) is expected. Note that r_ring is something like 50e-6 m, i.e. very small.
Similarly, the calculated effective mode indices belonging to the modes are also much smaller than n_core.
They all are approximately r_ring * n_core.
So the problem is that I expect n_eff to be in the order of n_core, but the n_eff calculated by Comsol (or n_eff's if there is more than one mode) are way too small.
Is there something special about the definition of n_eff in bent waveguides?
Since n_eff actually is the real part of the propagation constant (divided by k0, (k0=2 pi / lambda)), maybe the cylindrical coordinates somehow affect the definition of the propagation constant. Likewise, also the imaginary part which relates to damping of the electric field along propagation direction, may be altered.
I would greatly appreciate your answers.
regards,
H. Hartwig
regards,
H. Hartwig
3 Replies Last Post 2 déc. 2015, 19:58 UTC−5
