Domain Plot
My 3D model is consisted of 3 domains
and i want to plot the temperature at domain 1 only.
Can you help?
2 Replies Last Post 20 nov. 2011, 08:40 UTC−5
Posted: 1 decade ago 20 nov. 2011, 02:45 UTC−5
you have at least two ways ;)
1) you add a filter sub-node to your plot and you use the Boolean expression "dom ==1" or "dom==2" for domain 1, respectively 2 ...
2) you right click the data set, you duplicate your data set and then add a filter to the snd data set
Hi you have at least two ways ;) 1) you add a filter sub-node to your plot and you use the Boolean expression "dom ==1" or "dom==2" for domain 1, respectively 2 ... 2) you right click the data set, you duplicate your data set and then add a filter to the snd data set -- Good luck Ivar
Posted: 1 decade ago 20 nov. 2011, 08:40 UTC−5
Thanks!
I solve the problem :)
Thanks! I solve the problem :)
