Drawing a triangular hole in a cuboid
How can I draw a triangular hole in a rectangular channel? I am currently creating a 2D workplane and after drawing the required geometry in 2D, I am using the difference option. But the triangular region is not being selected. If this would have worked, I would have then used the extrude option.
If anyone has idea regarding this, kindly help.
3 Replies Last Post 19 juil. 2019, 08:36 UTC−4
Posted: 5 years ago 18 juil. 2019, 16:03 UTC−4
Updated: 5 years ago 18 juil. 2019, 15:54 UTC−4
Can you upload your mph file?
Jeff Hiller
Posted: 5 years ago 19 juil. 2019, 00:51 UTC−4
Updated: 5 years ago 19 juil. 2019, 00:48 UTC−4
Yes.
Yes.
Posted: 5 years ago 19 juil. 2019, 08:36 UTC−4
Updated: 5 years ago 19 juil. 2019, 08:27 UTC−4
Hi Aashna,
The issue is that before you can subtract a triangle from a rectangle, you need to have a triangle, and in your file there are segments that visually do form a triangle but you have not told the software that you want those three segments turned into a solid triangle. You can do that by converting the three segments into a curve, and then converting the resulting curve into a solid. Then you can select the triangle as the object to subtract from the rectangle.
See the attached file, where I did this for both triangles simulataneously.
PS: If you are starting with COMSOL, I highly recommend binge watching the videos on our Learning Center
Jeff Hiller
Hi Aashna, The issue is that before you can subtract a triangle from a rectangle, you need to have a triangle, and in your file there are segments that visually do form a triangle but you have not told the software that you want those three segments turned into a solid triangle. You can do that by converting the three segments into a curve, and then converting the resulting curve into a solid. Then you can select the triangle as the object to subtract from the rectangle. See the attached file, where I did this for both triangles simulataneously. Best, Jeff PS: If you are starting with COMSOL, I highly recommend binge watching the videos on our [Learning Center](https://www.comsol.com/learning-center)
