Using output data from a study step as an input parameter for a following step
Posted 17 févr. 2019, 18:28 UTC−5 Structural & Acoustics, Acoustics & Vibrations, Parameters, Variables, & Functions Version 5.4 0 Replies
I have a study where the first step is an Eigenfrequency analysis and the second step is a time dependent structural analysis with a sinusoidal force who’s frequency is the lowest Eigenfrequency evaluated in the first step.
I currently manually modify a global definition parameter to be the lowest eigenfrequency once the modal analysis has completed. That works fine, but I now want to do a batch sweep of the study, so need some automated mechanism to set a parameter to the lowest eigenfrequecy from step 1.
Can I refer to the eigenfrequency results data structure in the global definition parameters ? If so, it is not obvious to me how to get any visibility of the names of variables in the modal data set.
Many thanks for any help.
Hello Dan Bence
