Volume Average Data Set
Under the derived values tab, the option Volume Average determines the average value for an appropriate expression over a specified component of the resolved mesh geometry. I'm wondering if there's a way to output the data set that COMSOL uses to determine this averaged value? I know you can physically click and sample parts of the solution, outputting a table, but is there a way to program specific data points from a component at set intervals to be output as a table?
1 Reply Last Post 11 févr. 2019, 05:22 UTC−5
Posted: 6 years ago 11 févr. 2019, 05:22 UTC−5
You can use the Export > Data feature to evaluate a field in a set of points, typically the mesh points.
