How to model a coaxial cable in AC/DC electrical circuit interface?
Hi everyone,
I' am modeling a configuration of two devices which are connected by a coaxial cable. My model includes both Electrical Currents and Electrical Circuits interfaces: The only problem is the connection between them, I cannot find a "coaxial cable" tool in Electrical circuit interface.
Has anyone been faced with such a task? Many thanks in advance!
Sh.Arakelyan
5 Replies Last Post 26 déc. 2018, 21:04 UTC−5
Posted: 6 years ago 19 déc. 2018, 05:14 UTC−5
in the context of AC/DC the coaxial cable can be replaced by the equivalent circuit. This is a series inductor, series resistor and parallel capacitors. The coaxial cable must be much shorter than any wavelength in the model.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi, in the context of AC/DC the coaxial cable can be replaced by the equivalent circuit. This is a series inductor, series resistor and parallel capacitors. The coaxial cable must be much shorter than any wavelength in the model. Cheers Edgar
Posted: 6 years ago 20 déc. 2018, 20:00 UTC−5
Cheers Edgar
Thanks for your comment Mr. J. Kaiser,
the approach proposed by you is very rough approximation for my task, since I investigate the effect of coaxial cable length. Regards Shant
Sh.Arakelyan
>Hi, > >in the context of AC/DC the coaxial cable can be replaced by the equivalent circuit. This is a series inductor, series resistor and parallel capacitors. The coaxial cable must be much shorter than any wavelength in the model. > >Cheers >Edgar Thanks for your comment Mr. J. Kaiser, the approach proposed by you is very rough approximation for my task, since I investigate the effect of coaxial cable length. Regards Shant
Posted: 6 years ago 21 déc. 2018, 04:45 UTC−5
I would say, it depends. The equivalent parameters depend on the length, e.g. the capacitance for a typical 50 Ohm cable is 90 pF/m. The equivalent circuit can be good enough as long as the wavelength of the signal is much larger than the cable length. If the cable length gets longer than lambda/10 (this limit depends on the accuracy requirements) and you have to take transmission line effects into account you need a different approach.
Edgar J. Kaiser
www.emphys.com
Posted: 6 years ago 21 déc. 2018, 14:10 UTC−5
Modeling the coaxial cable with several lumps per wavelength will provide a good approximation. For "several"- four is enough, eight better, more probably not necessary. Most accurate will be to use T or pi sections.
D.W. Greve DWGreve Consulting
Modeling the coaxial cable with several lumps per wavelength will provide a good approximation. For "several"- four is enough, eight better, more probably not necessary. Most accurate will be to use T or pi sections. D.W. Greve DWGreve Consulting
Posted: 6 years ago 26 déc. 2018, 21:04 UTC−5
Updated: 6 years ago 27 déc. 2018, 02:00 UTC−5
Thanks a lot, for your valuable comments.
Sh.Arakelyan
