Overwriting the geometry inside Comsol
I have a geometry already present inside a comsol model. I there any way to update the geometry without deleting the previous geometry from the comsol server as I am using comsol 4.2 with matlab?
Vivek
2 Replies Last Post 5 sept. 2011, 08:55 UTC−4
Posted: 1 decade ago 2 sept. 2011, 15:35 UTC−4
there is no "versioning" of the geoemtry, you must redefine a new geometry (but you can have several in the same file, you need to define a new model though)
Hi there is no "versioning" of the geoemtry, you must redefine a new geometry (but you can have several in the same file, you need to define a new model though) -- Good luck Ivar
Posted: 1 decade ago 5 sept. 2011, 08:55 UTC−4
It depend on what you mean by "update".
You can always change parameters in an existing model by using the set() method on the object you wish to change. This work exactly as in the Comsol Desktop such that meshes, settings etc. are updated automatically before solving the model.
Using Matlab you can also introduce new geometrical objects (or remove them).
For very large changes to the geometry is can be easier to delete the old geometry and set up a new one, but that depends very much on what you wish to do.
Lars Gregersen
Comsol Denmark
Hi It depend on what you mean by "update". You can always change parameters in an existing model by using the set() method on the object you wish to change. This work exactly as in the Comsol Desktop such that meshes, settings etc. are updated automatically before solving the model. Using Matlab you can also introduce new geometrical objects (or remove them). For very large changes to the geometry is can be easier to delete the old geometry and set up a new one, but that depends very much on what you wish to do. -- Lars Gregersen Comsol Denmark
