Modal Analysis contact issues and Material specifications
Posted 16 juin 2011, 11:42 UTC−4 Materials, Studies & Solvers, Structural Mechanics Version 4.1, Version 4.2 0 Replies
My first issue is establishing contact pairs. I set it up so that the outside surface of the inner pipe is not able to cross through the inside surface of the outer pipe, yet, when I run the analysis I still get modes where the interior pipe passes through the exterior pipe. Any thought?
Also, I have another model of the same system, except for this time I place a small rubber seal in between the two pipes, close to the top. I can get the model to run if I keep all of the components the same material (i.e. model the seal as steel just like the two pipes) but, when I try to change the seal material to a rubber the model is not able to run giving an error:
Undefined value found.
- Detail: Undefined value found in the stiffness matrix.
There are 30 equations giving NaN/Inf in the matrix rows for the variable mod1.u
at coordinates
Any input would be greatly appreciated.
Hello Danielle Lower
