AC signal
Fernanda Camacho Alanis
My name is Fernanda. I have made a simulation where I apply a DC voltage to particular electrodes. In my real experiment, I am switching the voltage of the electrodes every 1ms. I have done the simulation in DC for the two cases; however, I would like to do it with time dependent. I don't know how to do. I would appreciate if you can help me.
1 Reply Last Post 11 mai 2011, 15:47 UTC−4
Posted: 1 decade ago 11 mai 2011, 15:47 UTC−4
so you say you ave managed to solve it in stationary, then you have two choices for time dependent:
Either you want to look at a transient so you express your "force" values with a time dependent function and you use a transient solver.
Or you you are in a constant frequency oscillation scheme, then you can use the frequency domain solver that does a harmonic development (à la Fourier if you want) and you define the amplitude and the frequency (the latter in the solver settings) You might also efine a frequency range start, step,stop) to get a fequency response.
Sorry I do not have COMSOL with my just now cannot look up your model
Hi so you say you ave managed to solve it in stationary, then you have two choices for time dependent: Either you want to look at a transient so you express your "force" values with a time dependent function and you use a transient solver. Or you you are in a constant frequency oscillation scheme, then you can use the frequency domain solver that does a harmonic development (à la Fourier if you want) and you define the amplitude and the frequency (the latter in the solver settings) You might also efine a frequency range start, step,stop) to get a fequency response. Sorry I do not have COMSOL with my just now cannot look up your model -- Good luck Ivar
