Fluid Flow
Hi every body,
I'm a new user for COMSOl. I learned how to model 2D single phas fluid flow in a parallel plates. Can I model two fluids moving in a parallel plates using COMSOL (The denser fluid displacing lighter one)? and how?
Your help is highly appreciated.
2 Replies Last Post 24 avr. 2011, 22:28 UTC−4
Posted: 1 decade ago 24 avr. 2011, 03:12 UTC−4
In the FLuid FLow module, you have the multi-phase flow, in particuler two phase level set and phase field
Hi In the FLuid FLow module, you have the multi-phase flow, in particuler two phase level set and phase field -- Good luck Ivar
Posted: 1 decade ago 24 avr. 2011, 22:28 UTC−4
Thank you so much Sir. I get it.
