Save a model as older version
Is it possible to save a model as older version? I have 5.3 and I would like to save model for previous vesion, e.g. 5.2.
6 Replies Last Post 7 févr. 2018, 07:01 UTC−5
Posted: 7 years ago 12 janv. 2018, 19:20 UTC−5
As far as I know it is not possible to do so.
ZHANG, Pu
School of Physics,
Huazhong University of Science and Technology
Posted: 7 years ago 15 janv. 2018, 08:00 UTC−5
Updated: 7 years ago 16 janv. 2018, 05:11 UTC−5
For obvious reasons, this cannot be done if you have used functionality which was not available, or has been significanly changed since version 5.2. In many cases, it is however possible:
Save the model as a Java file, compile it, and run the generated class file from the older version. This will work as long as there is nothing in that Java file which is not supported. A few such things can also be fixed by editing the Java file. So it may be worth trying.
Henrik
Henrik Sönnerlind
COMSOL
Hi, For obvious reasons, this cannot be done if you have used functionality which was not available, or has been significanly changed since version 5.2. In many cases, it is however possible: Save the model as a Java file, compile it, and run the generated class file from the older version. This will work as long as there is nothing in that Java file which is not supported. A few such things can also be fixed by editing the Java file. So it may be worth trying. Regards, Henrik
Posted: 7 years ago 16 janv. 2018, 04:06 UTC−5
If I want to send my simulation to someone who have version 5.2, what do I need to send? This .class and .mph, or just .class, or something else?
Thanks, Milana
Hi, If I want to send my simulation to someone who have version 5.2, what do I need to send? This .class and .mph, or just .class, or something else? Thanks, Milana
Posted: 7 years ago 16 janv. 2018, 05:16 UTC−5
Updated: 7 years ago 16 janv. 2018, 05:38 UTC−5
Hi Milana,
If we assume that you do not have 5.2, and your collegue has that version, the best would be that you sava as Java (preferably after having done a Compact History). You then send the Java file, so that the other user has a possibilty to edit it, if necessary.
Henrik
Henrik Sönnerlind
COMSOL
Hi Milana, If we assume that you do not have 5.2, and your collegue has that version, the best would be that you sava as Java (preferably after having done a Compact History). You then send the Java file, so that the other user has a possibilty to edit it, if necessary. Regards, Henrik
Posted: 7 years ago 6 févr. 2018, 13:12 UTC−5
Hi Henrik,
I have saved my model as java file
I don't know how to compile it , Can you please tell me the steps to compile a java file before openning it in the older version?
I searched for it and it said to enter compile command in the comsol server but I don't how that can be done for a spesific java file that already saved
Can you please help me with that ?
Thank You
Regards, Abdul
Hi Henrik, I have saved my model as java file I don't know how to compile it , Can you please tell me the steps to compile a java file before openning it in the older version? I searched for it and it said to enter compile command in the comsol server but I don't how that can be done for a spesific java file that already saved Can you please help me with that ? Thank You Regards, Abdul
Posted: 7 years ago 7 févr. 2018, 07:01 UTC−5
Hi Abdul,
You can use the comsolcompile command from a console window. If you have the binaries directory in the search path, then it is just
comsolcompile my_model.java
Without the path set, you can do something like (on Windows)
C:\"Program Files"\COMSOL\COMSOL53a\Multiphysics\bin\win64\comsolcompile my_model.java
Henrik
Henrik Sönnerlind
COMSOL
Hi Abdul, You can use the **comsolcompile** command from a console window. If you have the binaries directory in the search path, then it is just **comsolcompile my_model.java** Without the path set, you can do something like (on Windows) **C:\"Program Files"\COMSOL\COMSOL53a\Multiphysics\bin\win64\comsolcompile my_model.java** Regards, Henrik
