Eigenfrequency solver
Posted 29 nov. 2017, 03:50 UTC−5 Structural & Acoustics, Heat Transfer, Studies & Solvers 0 Replies
My model includes tow physics: Solid mechanic and heat transfer in solids. I want to study the effect of vibration and thermal condition in mechanical structure. I calculate the eigenfrequency for vibration load using only solid mechanical physics.
If I add the physics of heat transfer in solids. I get in the eigenfrequency solver that this physics is deactivated in the solver.
I want to know if heat transfer is included in the study because there is a lot difference between the results of both studies (mechanical/ mecanical+heat tarnsfer). Or there is another solution to resolve this problem.
Thank you
Hello Ayda Halouani
