How do I create a table with several expressions for several points?
I create into my geometry , points corresponding to a sensor. I define a selection "Points capteur"corresponding to the sensor points, defined into the geometry. I have 4 points.
I want to visualize into a table [x,y,z,normB] this selection.
But when I do
" Results-> Derived Values "
I create a node "point evaluation" and define the setting as following :
data --> solution1
selection --> Points capteur
I cannot choose several expressions !
I would like a table with 4 column [ x y z nomB] and 4 rows (I have 4 points).
Right now I just obtain one expression for one evalution.
Magnetic flux density norm x-Coordinate (T), Point: 9 Magnetic flux density norm x-Coordinate (T), Point: 10 Magnetic flux density norm x-Coordinate (T), Point: 11 Magnetic flux density norm x-Coordinate (T), Point: 16
3.4360828027820874E-8 3.434621825694353E-8 2.8343588212953192E-8 2.836062068199727E-8
How can I do a table with 4 column [ x y z nomB] and 4 rows (I have 4 points)?
thanks for your help.
0 Replies Last Post 21 mars 2011, 08:30 UTC−4
Hello Malvina Billeres
