How to import velocity field in energy equation
Hi all,
I have the result of the velocity field in the equation N-S, I want to use it to solve the convection problem without solve the N-S equation in the same time to reduce the freedom of degree or i must solve both of them (equation N-S and energy equation) ?
Thanks for your reply
Thanh Long
1 Reply Last Post 17 mars 2011, 21:22 UTC+1
Posted: 1 decade ago 17 mars 2011, 21:22 UTC+1
have you taken a look at the segregation solver steps (in V4 you add them manually, if COMSOL has not proposed one by default
Hi have you taken a look at the segregation solver steps (in V4 you add them manually, if COMSOL has not proposed one by default -- Good luck Ivar
