(inconsistent) Units and Functions
In order to solve for a fluid flow, I specify initial velocities through (analytical) functions (defined under definitions) with arguments x and y. For example, I have defined a function F(x,y)=(x^2-y^2)/R^2 (where R has been defined as a parameter with dimension, i.e. R=0.5[m]) and use this function to specify the initial x-velocity (for the time-dependent laminar flow). When substituting the function for the initial value, the text becomes orange (instead of black) indicating that I am using inconsistent units. I can understand this because F is in fact dimensionless. F should have the dimension [m/s] in order for Comsol not to complain. So how can I add to the function F the dimension of speed so that the text for the initial velocity becomes black instead of orange?
Thanks in advance,
Leon
5 Replies Last Post 15 mars 2011, 04:52 UTC−4
Lechoslaw Krolikowski
Posted: 1 decade ago 14 mars 2011, 11:53 UTC−4
Define F(x,y)=a(x^2-y^2)/R^2 where a=1[m/s] is defined as a parameter.
Andrzej
Hi, Define F(x,y)=a(x^2-y^2)/R^2 where a=1[m/s] is defined as a parameter. Regards, Andrzej
Posted: 1 decade ago 14 mars 2011, 12:07 UTC−4
No, this does not help (have tried it already). The text remains orange.
Posted: 1 decade ago 14 mars 2011, 15:13 UTC−4
Define F=a(x^2-y^2)/R^2 as a parameter. It works.
Andrzej
Hi, Define F=a(x^2-y^2)/R^2 as a parameter. It works. Regards, Andrzej
Magnus Ringh COMSOL Employee
Posted: 1 decade ago 15 mars 2011, 04:01 UTC−4
The expression a*(x^2+y^2)/R^2 works fine if you type it directly into a text box for a velocity.
Functions in COMSOL expect dimensionless inputs and outputs, so you need to "de-dimensionalize" the inputs:
F(x[1/m],y[1/m])
to remove the orange unit inconsistency indication.
Magnus Ringh, COMSOL
Hi, The expression a*(x^2+y^2)/R^2 works fine if you type it directly into a text box for a velocity. Functions in COMSOL expect dimensionless inputs and outputs, so you need to "de-dimensionalize" the inputs: F(x[1/m],y[1/m]) to remove the orange unit inconsistency indication. Best regards, Magnus Ringh, COMSOL
Posted: 1 decade ago 15 mars 2011, 04:52 UTC−4
Hi Magnus
Indeed this works for the function call variables, but the function itself is returning without units, so one need to multiply the function by *1[my_function_units] (or just F(x[1/m],y[1/m])[my_function_units] )
One can also define "F" as a variable, then the units are ported correctly. But, then the "F(x,y)" (one only uses "F") is "implicit" (this implicit notation is mostly not understood by the users, and it took me quite some time to catch the concept, and to understand where it really applies)
One also have to take care with Parametric or Continuation sweeps, the parameter used is supposed to be dimensionless, but this is not always nice in the tables or the plots, where one would prefer to see the full units not just a normalised value running from 0 to 1.
Therefore many users set up a parameter that runs over their variable range, there too one must add the units in the BC references.
Final case where I notice we often remain with orange color, even if everything is OK: when referring to other physics dependent variables. Sometimes we need to load the initial conditions to get all oranges returning to black.
Once you know about it, its easily to check, I highly appreciate these units checks, as it regularly corrects small typos and formula mismatches
Hi Magnus Indeed this works for the function call variables, but the function itself is returning without units, so one need to multiply the function by *1[my_function_units] (or just F(x[1/m],y[1/m])[my_function_units] ) One can also define "F" as a variable, then the units are ported correctly. But, then the "F(x,y)" (one only uses "F") is "implicit" (this implicit notation is mostly not understood by the users, and it took me quite some time to catch the concept, and to understand where it really applies) One also have to take care with Parametric or Continuation sweeps, the parameter used is supposed to be dimensionless, but this is not always nice in the tables or the plots, where one would prefer to see the full units not just a normalised value running from 0 to 1. Therefore many users set up a parameter that runs over their variable range, there too one must add the units in the BC references. Final case where I notice we often remain with orange color, even if everything is OK: when referring to other physics dependent variables. Sometimes we need to load the initial conditions to get all oranges returning to black. Once you know about it, its easily to check, I highly appreciate these units checks, as it regularly corrects small typos and formula mismatches -- Good luck Ivar
