heat transfer coefficient
I am an Electrical Engineer and I am not much familiar with heat transferring issues. I have a structure made of silcon and silica and I need to know how does it dissipate heat. In the martial property I have to set "heat transfer coefficient" and I don't know what is that and even there isn't any littérateur on heat transfer coefficient of silicon or silica. Can anybody give me some idea?
Faraz
2 Replies Last Post 11 mars 2011, 01:27 UTC−5
Posted: 1 decade ago 10 mars 2011, 18:13 UTC−5
Heat transfer coefficient is not a property of the material, but of everything around it. If the air around your boundary is very stagnant, the coefficient may be 5-10 W/m^2/K. If it is moving fast, as in blown over by a CPU fan, it may be higher, perhaps around 50-100 W/m^2/K
Hope this helps.
Ozgur
Faraz
Heat transfer coefficient is not a property of the material, but of everything around it. If the air around your boundary is very stagnant, the coefficient may be 5-10 W/m^2/K. If it is moving fast, as in blown over by a CPU fan, it may be higher, perhaps around 50-100 W/m^2/K Hope this helps. Ozgur [QUOTE] Hi I am an Electrical Engineer and I am not much familiar with heat transferring issues. I have a structure made of silcon and silica and I need to know how does it dissipate heat. In the martial property I have to set "heat transfer coefficient" and I don't know what is that and even there isn't any littérateur on heat transfer coefficient of silicon or silica. Can anybody give me some idea? Thanks Faraz [/QUOTE]
Posted: 1 decade ago 11 mars 2011, 01:27 UTC−5
my engineering "rule of thumb" values are:
1 atm air, normal temperature 20°C
very calm air 2[W/m^2/K]
normal laboratory air 5[W/m/K]
gentle air bow 10[W/m/K]
forced air blow 20-40[W/m/K]
Hi my engineering "rule of thumb" values are: 1 atm air, normal temperature 20°C very calm air 2[W/m^2/K] normal laboratory air 5[W/m/K] gentle air bow 10[W/m/K] forced air blow 20-40[W/m/K] -- Good luck Ivar
