Two parameters sweep and plot
Hi, all
I use two parameters sweep in comsol 4.1 to get a function of transmission efficiency vs period and depth of my model. The outer sweep is depending on depth and the inner sweep is depending on period, each of the two parameters is correspond to a transmission efficiency. I want to make the depth as x axis,period as y axis, and efficiency as z axis.
How can i obtain this figure in COMSOL? Or can i get a data set with those parameters and efficiency?
Thanks.
1 Reply Last Post 9 mars 2011, 11:07 UTC−5
Posted: 1 decade ago 9 mars 2011, 11:07 UTC−5
I'm not sure you can within COMSOL GUI, certainly within Matalb, but otherwise dump the values into some tables and get the raw data into another programme (worst case EXCEL ;) by the way there is an option to transpose a 2D table, then you could perhaps add several layers of 2D tables plots but I believe it must be set up manually
Hi I'm not sure you can within COMSOL GUI, certainly within Matalb, but otherwise dump the values into some tables and get the raw data into another programme (worst case EXCEL ;) by the way there is an option to transpose a 2D table, then you could perhaps add several layers of 2D tables plots but I believe it must be set up manually -- Good luck Ivar
