Plane poiseuille flow between 2 flat plates
Anindita Bhattacharya
Hi everyone,
I am new to COMSOL. I am trying to simulate a plane Poiseuille flow between 2 flat plates with a gap of 0.05 m and a pressure difference of 0.1 Pa over 0.1 m length (giving dP/dx=-1 Pa/m). The fluid is water- dynamic viscosity is 8.9*10^(-4) Pa s.
So, according to ocw.mit.edu/courses/mechanical-engineering/2-25-advanced-fluid-mechanics-fall-2013/equations-of-viscous-flow/MIT2_25F13_Couet_and_Pois.pdf
my maximum velocity should be 0.35 m/s but according to the simulation file I have attached, I am getting
something close to 0.2 m/s.
Could you please tell me what I am doing wrong?
Best Regards
Anindita
3 Replies Last Post 28 mars 2017, 00:03 UTC−4
Posted: 8 years ago 27 mars 2017, 18:46 UTC−4
Hi everyone,
Best Regards
Anindita
I think the difference arises from the fact that the formulas in the link you sent are derived for 1D flows. But your model is 3D. Try to increase the aspect ratio and see if the difference vanishes.
I didn't check anything else though.
Also, do not expect to get the same answer as the analytical solution when using numerical methods.
Amin,
[QUOTE] Hi everyone, I am new to COMSOL. I am trying to simulate a plane Poiseuille flow between 2 flat plates with a gap of 0.05 m and a pressure difference of 0.1 Pa over 0.1 m length (giving dP/dx=-1 Pa/m). The fluid is water- dynamic viscosity is 8.9*10^(-4) Pa s. So, according to https://ocw.mit.edu/courses/mechanical-engineering/2-25-advanced-fluid-mechanics-fall-2013/equations-of-viscous-flow/MIT2_25F13_Couet_and_Pois.pdf my maximum velocity should be 0.35 m/s but according to the simulation file I have attached, I am getting something close to 0.2 m/s. Could you please tell me what I am doing wrong? Best Regards Anindita [/QUOTE] I think the difference arises from the fact that the formulas in the link you sent are derived for 1D flows. But your model is 3D. Try to increase the aspect ratio and see if the difference vanishes. I didn't check anything else though. Also, do not expect to get the same answer as the analytical solution when using numerical methods. Amin,
Posted: 8 years ago 27 mars 2017, 19:20 UTC−4
Hi Amin,
Thank you so much. I get much better results, if I have length and depth=0.1 m and width =0.005m. So I guess aspect ratio was the culprit here. What mesh would you however suggest to get a smoother velocity profile?
Best Regards
Anindita
Hi Amin, Thank you so much. I get much better results, if I have length and depth=0.1 m and width =0.005m. So I guess aspect ratio was the culprit here. What mesh would you however suggest to get a smoother velocity profile? Best Regards Anindita
Posted: 8 years ago 28 mars 2017, 00:03 UTC−4
Hi Amin,
Best Regards
Anindita
Of course the finer, the better.
You may also play with shape orders and discretization (P2+P1, P3+P2) and see if it gives what you want.
Amin,
[QUOTE] Hi Amin, Thank you so much. I get much better results, if I have length and depth=0.1 m and width =0.005m. So I guess aspect ratio was the culprit here. What mesh would you however suggest to get a smoother velocity profile? Best Regards Anindita [/QUOTE] Of course the finer, the better. You may also play with shape orders and discretization (P2+P1, P3+P2) and see if it gives what you want. Amin,
