Calculating Line average
I know that from "Results >> Derived values >> Line Average", I can average an expression over the line of interested.
In my model, I like to use Line average in the middle of a domain where there is no line to chose for line average. How can I define a line and use it for Line average?
Hamed
5 Replies Last Post 22 févr. 2017, 21:33 UTC−5
Posted: 8 years ago 31 janv. 2017, 16:02 UTC−5
Hello Hamed,
To avoid having to re-solve the model, after you add the line you need to use "Update solution" instead of "Compute". Then compute the line average the usual way.
Hello Hamed, To avoid having to re-solve the model, after you add the line you need to use "Update solution" instead of "Compute". Then compute the line average the usual way. Best, Jeff
Posted: 8 years ago 14 févr. 2017, 18:00 UTC−5
Thank you Jeff for the answer.
My question was how to define a line in the domain so I can select it in the line average?
Hamed
Thank you Jeff for the answer. My question was how to define a line in the domain so I can select it in the line average? Thanks, Hamed
Posted: 8 years ago 15 févr. 2017, 02:49 UTC−5
I suggest that you create a Cut Line data set.
[QUOTE] My question was how to define a line in the domain so I can select it in the line average? [/QUOTE] I suggest that you create a Cut Line data set.
Posted: 8 years ago 15 févr. 2017, 08:51 UTC−5
Indeed, Gunnar's solution is better than mine.
If for some reason you still decide to do it the way I mentioned above, just draw the line like you draw any line in COMSOL: in the Geometry branch of the Model Builder tree use a Polygon of the Open Curve type.
Indeed, Gunnar's solution is better than mine. If for some reason you still decide to do it the way I mentioned above, just draw the line like you draw any line in COMSOL: in the Geometry branch of the Model Builder tree use a Polygon of the Open Curve type. Best, Jeff
Posted: 8 years ago 22 févr. 2017, 21:33 UTC−5
Thank you Gunnar and Jeff.
